Front shock absorber revision Options
#1 Posted : 22 June 2013 15:06:55
Issue 26 contains a slight revision of assembly of the shock absorber assembled at Issue 4, which is to improve the performance of the shock absorbers.
The issue 4 shock will need to be emptied of its oil content back into the bottle, the shaft removed from the shock body, and a washer added to the protruding shaft side of the assembly. This is advised within Issue 26 where the additional washer is provided and the second front shock absorber is assembled as per the revision.
If you are storing your RB7 parts for later assembly, it would be a good idea to assemble the Issue 4 shock absorber at Issue 26.
SWINE1
#2 Posted : 23 June 2013 14:55:25
How exactly do you get it back in the bottle?? will they be supplying a miniature funnel LOL
Is this bottle needed to fill all shockies?? i am assuming that there is 4??
#3 Posted : 23 June 2013 15:35:23
The spout tip of the bottle is removed, and the oil simply poured back in, without need of a funnel.
There is adequate oil in the bottle for all four shocks along with the revision for one shock.
SWINE1
#4 Posted : 24 June 2013 12:12:47
excellant......
skyfire
#5 Posted : 24 June 2013 13:58:03
Publisher Medal: Featured Build of the MonthActive Service Medal: 500 post active service MedalBuild-Diary Medal: Build-Diary Medal of HonourRed Medal: Red Medal
What does this washer actually do and how critical is it. Don't think I can be bothered pulling the shock apart, just to add a washer.
#6 Posted : 24 June 2013 14:04:00
It slows the rate of oil passing through the piston holes on the upstroke and is noted as an improvement to the performance.
Its only a 10 min task to add the washer.
Waza27
#7 Posted : 25 June 2013 07:03:26
This is good to know thanks. As i was about to start putting the shock together.
Melkerri
#8 Posted : 01 July 2013 14:41:43
Rank: Beginner Level 3
Im assuming that means that Kyosho is placing an extra washer in part 26 for the issue 4 shock? Sorry for asking an obvious question as it appears, I just want to make sure is all. Thankyou:)Blushing Confused
Kyosho/Deagostini RB7 Rox!!
#9 Posted : 01 July 2013 15:17:45
Unsure at this stage if the washers are just relevant to just the front shocks or all four, but if they are, then washers will also be provided for the rear shocks.
Melkerri
#10 Posted : 02 July 2013 07:17:49
Thanks Tomick for the speedy reply. If there is a chance that Kyosho/DeAg doesn't issue the extra part for some reason, then I guess it would be a stock standard part that we could easily get from most RC Kyosho stockists? Thanks again!
RB7 Rox!!!
cs2000
#11 Posted : 25 October 2013 01:35:34
Just wanted to check this.
Received my first load of parts today and downloaded the instruction PDF online. Got to the shock part and stopped. Is this still the correct thing to do, or has the PDF been corrected some time in the months since this was first advised?
#12 Posted : 25 October 2013 07:30:57
BigGrin Hi cs2000
I would go with the revision and wait for the washer that's needed to arrive then its just one assembly to do and no messing about with draining oil ect. Hope this help
cs2000
#13 Posted : 25 October 2013 10:28:05
Cool, that makes sense, just wondered if it had been fixed since the change had been applied. That's cool anyway, il leave it in its cardboard wrapper and assemble it in a few months time :)
BTW: I hope nothing I ever do is as fiddly as that front wing Blink Cursing
Nightrider
#14 Posted : 02 December 2013 06:02:04
Quick question....
I am beginning to assemble the front shocks now...
I have received the washer from issue 26.
Now where do I get the steps to complete this process?
Do u follow the instructions in the magazines?
Thanks
#15 Posted : 02 December 2013 08:59:19
Follow the issue 26 instructions
Nightrider
#16 Posted : 02 December 2013 10:40:47
Thanks mate.
Nightrider
#17 Posted : 02 December 2013 16:36:16
Sorted! Follow issue 26 peeps
Straight forwards
This page was generated in 0.251 seconds.
