spitfire wing ribs Options
teroy9747
#1 Posted : 29 November 2013 21:53:40
Rank: Newbie
Hi, I have just started building the first wing section of the spitfire but I am a bit confused.The written instructions tell me to glue ribs 3-4-5-6 into slots 5-7-9-11 on main wing spa,which I have done,and as I have moved on to next set of ribs I have noticed on the photographs the ribs 3-4-5-6 are shown fixed in slots 4-6-8-10, could you please tell me which is correct and how do I get glued ribs back out of wrong slots if that is the case.Thanks Teroy.
spikee
#2 Posted : 29 November 2013 22:03:29
If they are glued into the wrong slots,the easiest way to unstick them (assuming youve used white wood glue) is to soak in hot water for a few mins,and youll be able to then pull them apart dead easy and intact.Allow to dry overnight on a flat surface (with something heavy on top to make sure they dont warp) then just glue as normal.
Jon
#3 Posted : 29 November 2013 22:39:29
Hi Teroy
Make sure you are counting the end of the rib as a slot... Each of the ribs you are fixing will have a tab at the end and will be positioned so that each rib will miss a rib... From what you are saying it sounds like your build is correct but your not counting the end slot.... Which is not a slot but will be for rib 1.... Look at Tomicks official build under stage 11 here and if yours looks the same then you have done it correct.
http://forum.model-space...aspx?g=posts&t=8130
If you provide a picture then I can confirm this but don't start taking anything apart just yet
Spencer
This page was generated in 0.126 seconds.
