Joined: 27/11/2013 Posts: 3 Points: 9 Location: Melbourne
Hi I am wondering if anyone else has noticed that on left side chassis the hole behind the fuel tank post is out of line and the last hole at the back of the side to main chassis mount is also slightly out. Also on the right side chassis the 2 holes behind the fuel tank post don't line up. All 4 holes are meant to line up with the main chassis and mine don't.
 Rank: Pro  Groups: Joined: 11/04/2013 Posts: 119 Points: 347
I think the posts for the fuel tank on the plastic side parts of the chassis are meant to be slightly out of alignment. That's often how r/c fuel tanks are 'cuz they have weird shapes. But if u think that u got a dud chassis it might be best to ask Bissett mags for a replacement issue 6
 Rank: Beginner Level 1  Groups: Registered
Joined: 23/11/2013 Posts: 5 Points: 15 Location: London
Maybe posting a photo of your chassis will help others identify whether it is incorrect?
Ive tried to take a photo but its hard to pick up in a photo. Either side of the main metal chassis there are 4 holes and in issue 31 you screw 2 screws either side to attach the side chassis to the main. What I'm saying is after that if i look at the remaining 2 holes on either side of the main chassis the side chassis ones are out of alignment to the main chassis holes.
Just curious if anyone else has the same problem otherwise i'll ring up and get a replacement.
they are about 2 mm out but it's enough for in future issues if i need to put a screw through those holes it won't fit
KohlSmith wrote:Ive tried to take a photo but its hard to pick up in a photo. Either side of the main metal chassis there are 4 holes and in issue 31 you screw 2 screws either side to attach the side chassis to the main. What I'm saying is after that if i look at the remaining 2 holes on either side of the main chassis the side chassis ones are out of alignment to the main chassis holes.
We've not had any reports of this up to now.
