 Rank: Beginner Level 1  Groups: Registered
Joined: 23/11/2013 Posts: 5 Points: 15 Location: London
Morning all,
When subscribing I was offered a choice of starting at issues 1, 2 or 3.
I chose 1, but wasn't really sure why.
If I had chose 3, would I have received the first 3 packs together then joined in the subscription from there?
Or would I have received pack 3 and missed out on packs 1 and 2?
Naturally, I want to make sure I've done the right thing (or will contact De Agostini customer services), but if by choosing pack 3 to start from I'll receive the first 3 packs together I'd rather do that and build in line with everybody else.
If anybody can shed some light on this I'd be very grateful.
Cheers.
Hi Steven and welcome to the forum.. I think you have done the right thing by starting your subscription from issue 1. If you had started from issue 3 then you wouldn't receive the first two issues unless your ordered them as back issues.... Hope this helps and hope you enjoy your build,,, Regards Alan
Gandale wrote:Hi Steven and welcome to the forum.. I think you have done the right thing by starting your subscription from issue 1. If you had started from issue 3 then you wouldn't receive the first two issues unless your ordered them as back issues.... Hope this helps and hope you enjoy your build,,, Regards Alan Thanks Alan, Tempting to start at 3 and order the first two on back order, but I guess it could be unpredictable as to when the first 2 would turn up? Maybe I'll just start from the beginning and work on my patience....I think we'll all need it
 Hi Steve The reason it says start at issue 1,2 or 3 is because in some country's the set is available from newsagents also so some people may have already got issue 1 and 2 say thats the reason for the choice. Hope this puts your mind to rest regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
