Which Starting Issue? Options
StevenH72
#1 Posted : 24 November 2013 11:05:09
Morning all,
When subscribing I was offered a choice of starting at issues 1, 2 or 3.
I chose 1, but wasn't really sure why.
If I had chose 3, would I have received the first 3 packs together then joined in the subscription from there?
Or would I have received pack 3 and missed out on packs 1 and 2?
Naturally, I want to make sure I've done the right thing (or will contact De Agostini customer services), but if by choosing pack 3 to start from I'll receive the first 3 packs together I'd rather do that and build in line with everybody else.
If anybody can shed some light on this I'd be very grateful.
Cheers.
#2 Posted : 24 November 2013 11:11:28
Hi Steven and welcome to the forum.. I think you have done the right thing by starting your subscription from issue 1. If you had started from issue 3 then you wouldn't receive the first two issues unless your ordered them as back issues.... Hope this helps and hope you enjoy your build,,,Cool Cool
StevenH72
#3 Posted : 24 November 2013 11:16:12
Thanks Alan,
Tempting to start at 3 and order the first two on back order, but I guess it could be unpredictable as to when the first 2 would turn up?
Maybe I'll just start from the beginning and work on my patience....I think we'll all need it BigGrin
#4 Posted : 24 November 2013 11:24:15
BigGrin Hi Steve
The reason it says start at issue 1,2 or 3 is because in some country's the set is available from newsagents also so some people may have already got issue 1 and 2 say thats the reason for the choice.
Hope this puts your mind to rest
