7 Pages 123>»
Malc's Yardley Mclaren M23 build Options
#1 Posted : 23 November 2013 10:51:36
This car's debut was at Kyalami, just up the road from me, in 1973. Denny Hulme took it to pole but unfortunately only finished 5th. During the next couple of years it evolved and brought Mclaren it's first drivers and constructors championships.
Since the De'ag MP4/23 got me hooked on F1 models I'm aiming to build various cars and this 1/12 M23 is my next project. The Tamiya kit features the high airbox and vertical rear wing post but I want to get a little closer to the appearance of the Hulme car. I've aquired a few bits and pieces to help with that.
It's going to take me a while to finish especially since I'll be attempting some airbrush work for the first time. I'm still in learning mode so all advice is very welcome.
#2 Posted : 23 November 2013 10:53:44
The kit still in it's packaging. Almost to good to open BigGrin
#3 Posted : 23 November 2013 10:55:21
Plus some extras for good measure
#4 Posted : 23 November 2013 12:35:13
BigGrin Hi Malc
Looks like a nice kit and etch too yummy
#5 Posted : 30 December 2013 09:03:09
Decided to start with the engine. used a bit of filler on some of the joint lines.BigGrin
My wife bought me an airbrush setup for xmasLove so I christened it on this little DFV. It seems to take longer to clean the equipment than to do the spraying Laugh
#6 Posted : 12 January 2014 15:04:50
A little detail added to the heads. Steady hand required for this stuff Mellow
Heinzy
#7 Posted : 13 January 2014 08:59:23
Steady Hand! Understatement of the year!
Engines looking great BigGrin
The Brawn Build
Wentworth Court Dolls House
The MP4/4 Build
[ulr=http://forum.deagostini.co.uk/default.aspx?g=posts&t=36693]The 97T Build[/url]
#8 Posted : 08 February 2014 14:13:05
Water and oil pumps added to the lower sides of the engine. I decided to reduce the bling appearance of Tamiya Chrome plating on the canister oil filter with a light dust of metallic silver.
#9 Posted : 10 February 2014 21:27:13
Looking sweet Malc and nice to see your taking your time on this classic Cool
Spencer
#10 Posted : 08 March 2014 13:57:47
A little more done on the engine/gearbox. I've not worked with photo-etch parts before but the result on the brake discs was really pleasing.BigGrin
The plug leads and fuel lines are quite fiddly and I haven't glued anything in place yet. Can't imagine what a 1/20 scale must be like for wiring up Laugh next week the calipers and some suspension bits.
Tanasius
#11 Posted : 08 March 2014 15:16:08
Rank: Amateur level 2
Very nice, can show you what 1/20 is like very small.
Rob.
Tanasius attached the following image(s):
Builds, deag Zero, D51, Senna MP4/4
#12 Posted : 09 March 2014 14:51:08
Oh no ! I'm going to really struggle with something like that BigGrin.
#13 Posted : 06 April 2014 16:01:39
Decided to change the plug leads for some thinner cable and added plug covers from some thin plastic sheet punched at 4mm diameter
#14 Posted : 06 April 2014 16:04:11
Some work on the rear suspension. I've added some detail to the Koni dampers with a home made decal. Not sure it's too original but I like it BigGrin
#15 Posted : 07 April 2014 14:04:04
Nice work Cool
#16 Posted : 07 April 2014 17:22:16
Tomick wrote:
Nice work Cool
Thank youBigGrin Appreciate the kind comments
schueyking
#17 Posted : 13 April 2014 20:35:11
BigGrin Nice work Malc! That is sweet!!!
Chris BigGrin
Heinzy
#18 Posted : 14 April 2014 09:15:21
You might as well stick this on display as is!!
Looking amazing!
The Brawn Build
The MP4/4 Build
#19 Posted : 17 April 2014 15:06:37
Thanks for the comments. I'm really enjoying the details and learning lots about paints and finishes.BigGrin
#20 Posted : 28 April 2014 14:07:41
Nearly finished the engine and transmission. Still got to permanently attach the radiators and glue the gearbox to the block. I'm trying to get a reasonable look to the hydraulic fittings ( A/N joints? )I've used some plastic tube sprayed metallic red and put metallic blue on the connectors on the radiators.
Started work on the exhaust pipesBigGrin
7 Pages 123>»
This page was generated in 0.272 seconds.
