Joined: 02/09/2012 Posts: 515 Points: 1,515 Location: Burnley
Hi, I have now sprayed all the metal parts I had primed with Tamiya Metallic gold. Once dried, I painted some of the detail in matt black as per the instructions.   I have dry fitted one of the balcony rails, and the width seems very wide and obscures the door I have fitted. Need to rethink this area? Regards claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Waiting in the wings: Polarlights Spindrift from Land of the Giants.
finished: 007 Iconic DB5.
Lovely work Claret, really looking the biz there...... Regards Alan
Hi Alan, Thanks you. How did you overcome the added balcony door with the metal rail? Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
claret wrote:Hi Alan,
Thanks you.
Regards Claret Hi Claret, I found the metal rail didn't interfere with my doors as I deliberately set them closer to the hull than the rail.... Regards Alan
Hi Alan, Thanks for the reply. I may have to move the doors. Hit another stumbling block, still waiting over two months for CMB to send 1mm diamond mesh I ordered. Used the standard mesh and turned it through 45 degrees, but have run out of this now. One one window to do aswell!!  . Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
claret wrote:Hi Alan, Thanks for the reply. I may have to move the doors. Hit another stumbling block, still waiting over two months for CMB to send 1mm diamond mesh I ordered. Used the standard mesh and turned it through 45 degrees, but have run out of this now. One one window to do aswell!!  . Regards Claret if you want a different mesh supplier drop me a PM I have a good one. “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
claret wrote:Hi Alan, Thanks for the reply. I may have to move the doors. Hit another stumbling block, still waiting over two months for CMB to send 1mm diamond mesh I ordered. Used the standard mesh and turned it through 45 degrees, but have run out of this now. One one window to do aswell!!  . Regards Claret Hi Claret, obviously I didn't use the mesh that came with the issues so still have some of that spare... If you wish then you could PM me your details and I'll send it to you.... Let me know... Regards Alan
Hi Alan, Many thanks for your help. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi clarrett. Really nice looking build. Look forward to seeing more Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Joined: 25/01/2012 Posts: 134 Points: 385 Location: Berwick Upon Tweed
Claret the paint looks great, Its starting to take shape. Keep up the good work Cheers Peter
Current builds: Amati 1:200 Hood; D51 200 Bought and on the waiting list: HMS Endeavour's Longboat, 1:90 San Juan Nepomuceno, Titanic Lifeboat,1:200 Bismarck Strip and Rebuild [b]Built:1:250 Titanic
Hi Claret, A super neat build in progress there. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Nice work Claret smart paint work  Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Hi Ian, Peter, Derek & Martyn, Thanks for looking in, and many thanks for the kind comments. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi, Work has started on the transom. A little bit of fettling required to get a good fit, but slow process, allowing paint and glue etc to cure.  More to follow at the weekend. Regards claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Looking great Claret, now that you are starting to apply the bling this is where she will start to take on her stunning good looks.....  .. Will be watching your progress... Regards Alan
Hi Alan, Thanks for looking in and your kind comments. Hopefully some more bling this weekend! Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
 Lovely work Claret  Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Hi Martyn & Dominic, Thanks for looking in and commenting. The black is a matt black from wilkinsons, their own brand! Regards claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi Claret thought I would say Hello She is looking great,very,very clean neat work Kind Regards Nigel
Hi Nigel, How are you? Thanks for looking in and the kind comments. Regards claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
