8 Pages «<45678>
Moebius 1/32 Flying Sub Diary Options
#101 Posted : 02 November 2013 21:54:47
Beautiful work Claret Drool
Spence
claret
#102 Posted : 04 November 2013 09:01:36
Hi Guys,
Many thanks for the kind comments.
Will try and post a few pics over the week, need to progress on the sotsBigGrin .
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
claret
#103 Posted : 11 November 2013 09:01:31
Hi,
A little more done.
Firstly I frosted the core reactor windows (must be leaded windowsLOL ) with 1200 wet and dry.
and after sanding...
claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#104 Posted : 11 November 2013 09:10:36
Hi,
For the lighting effect, I boxed all the instrument panels and core windows to be lit up with 2mm styrene card behind the panel and used aluminium sticky foil to stop light escaping.
I had purchased the VoodooFX lighting kit which i soldered up using different leads, 11 LED's in total so far and 5 more to be constructed and soldered to the PCB.
I tested them this week and all the LED's came on!!!! Dry fitted a couple of panels to see how they look and was impressed with the result. especially the core window, the led changes colour every few seconds.
Thats all for now.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
benny b
#105 Posted : 11 November 2013 10:48:43
hi claret very impressive great build Drool benny.
#106 Posted : 11 November 2013 13:49:18
Looking better than the original set!! Cool
J
#107 Posted : 11 November 2013 19:07:40
Stunning work Claret, all credit to you....Drool Drool
#108 Posted : 11 November 2013 19:40:29
BigGrin Hi Claret
Love the lights they defo bring her to life
claret
#109 Posted : 11 November 2013 21:54:29
Hi Benny, Jase, Alan & andy,
Many thanks for your nice comments.
I was relieved all the LED's worked and surprised how well they bring the model to life.
Still a lot to do before I can glue the interior in place and set all the lighting up.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
Foz
#110 Posted : 11 November 2013 21:58:58
Very repressive Claret. Look forward to your progress.
Foz
#111 Posted : 11 November 2013 22:03:32
claret
#112 Posted : 12 November 2013 08:33:32
Thanks Steve.
Much appreciated.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#113 Posted : 18 November 2013 09:00:27
Hi,
Some more progress.
The PE kit has 5 microphones with it and suggests installing them on the frame uprights. however, checking the film stills, the only microphone I can see is on the side of the back instrument panel.
I proceed to cut the microphone one and glued it onto 2mm styrene. Once the glue was dry i cut and sanded the styrene to the shape of the mic. I then primed and painted matt black. I used 0.35mm solder wire coiled around a 1mm dry bit and primed, painted black and glued to the mic. result below.
And glued in place...
claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#114 Posted : 18 November 2013 13:44:29
Hi,
I have made three air cylinders from 5mm plastic rod, 1mm brass rod and wire. Painted and installed under the bunk. I used de-soldering braid for the strap to hold them in place. result below:
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#115 Posted : 18 November 2013 13:51:20
Hi,
Although I am lighting the model extensively, I have not wanted and wires to come out of the model to the battery and switch.
To overcome this, I am going to put the battery into the access tunnel which is accessed by the hatch seen in previous photos and a hatch at the rear of the craft. the later is going to be the point where i can switch the lights on and house the battery.
I have hinged the rear hatch and spring loaded it so it shuts back when the battery is in place etc.
It works really well, and opens and closes with not to much force.
claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#116 Posted : 18 November 2013 13:54:00
Hi,
Just a couple of dry assembled photos to put everything into perspective.
Thats all for now.
Thanks for looking in.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#117 Posted : 18 November 2013 22:17:04
Stunning, some beautiful details being shown on this build Claret, credit to you.....Drool Drool
claret
#118 Posted : 19 November 2013 08:45:28
Hi Alan,
Thanks.
This has been a nice distraction from the SOTSBigGrin
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
Foz
#119 Posted : 19 November 2013 14:19:30
HI Claret.
A stunning build and a real eye for the detail. Really look forward to your progress.
Foz ThumpUp
#120 Posted : 19 November 2013 19:31:01
Hi Claret,BigGrin
I just love those scuba tanks,Cool Cool Cool
Now all you need is:
Wet suits
Regulators
Fins
Masks
Weight belts
Dive computers (Wrist size)
LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL LOL
Only jesting, really loving the detail you are adding.
Love Love Love Love Love Love Love Love Love Love
8 Pages «<45678>
This page was generated in 0.172 seconds.
